Playstation 5 stopped working
Lfreeman1994
Hello, just wondering if anyone can help my playstation 5 has decided to stop working after owning it for 2 months. Do i need to go through EE or contact playstation directly to get it replaced on warranty?
Ive tried all the troubleshooting through the playstation website but still not working.
Any help would be appreciated thank you
Profile closed
Not applicable
Hi @Lfreeman1994
Welcome to the EE Community,
you will need to contact Sony directly to arrange for the console to be fixed under the warranty Sony's direct number is 0203 538 2665.
David
Where can I find a ‘proof of purchase’. Sony are asking for it
Christopher_G
Hi @Lydia88
Did you get your PS5 as an add to plan product?
Hi, yes I did. 🙂
Christopher_G
OK, thanks @Lydia88
Our Mobile Care team should be able to send you some proofs, if you contact them. 🙂
