Minecraft Realms is not accessible within EE home network
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-01-2023 05:56 PM
I have minecraft at home set up on several devices but cannot connect to Realms from within my home EE network.
I cannot connect to a working "Realm" from the Wifi (2.4) or cable in my house using: Android, Windows or XBox MC clients. When I try, I can find the realm in the list, select it and then it eventually fails after sitting on "Loading Resource Packs" for a while.
However, I can connect on Android when using data, and I can also connect on Windows via WiFi tethering using my mobile, so it isn't MC itself.
I have standard uPnP and security enabled. I have tried port forwarding on 80, 443 and 40000-65000 but no luck.
When TCPView, I was able to see the difference between the two scenarios:
- Tethered to mobile I get a single UDP connection on a high port to destination *. That's all that gets created.
- Home Network I get up to 25 connections, most TCP, most seem transient. I still get a few UDP v6 connections too.
Has anyone encountered this before or have any ideas how it might be resolved. The Smart Hub is configured in a fairly standard way other than that.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-01-2023 09:57 AM
Hi @Bannini.
I'm not sure what would be stopping this from working.
One of our community broadband experts may be able to offer some advice on how to get this working.
Jon
- Smart Hub 3 (SH31b) Plus - DDNS back ! Older WiFi devices wont connect - Fix in Broadband & Landline
- Static Public IP in Mobile Broadband
- Can't reset old (BT Smart Hub) Wifi Controls in Broadband & Landline
- Can no longer access admin page for 4G Wifi Mini Hub in Mobile Broadband
- Alternative to Smart Hub Plus - DNS and VOIP service in Broadband & Landline
