16-09-2026 06:30 PM
Is there a way to block all gambling sites and apps?
I just can’t be trusted so need to get rid completely.
17-09-2026 10:38 AM - edited 18-09-2026 11:09 AM
Hi @Furrysides
Welcome to our community and thanks for reaching out about this.
As @XRaySpeX has said, EE's parental controls can help, as both the Moderate and Strict settings block access to gambling websites when you're using the EE mobile network. The Strict setting also blocks additional categories of content. However, it's worth noting that these controls only work when connected to the EE mobile network, not when using WiFi, a VPN, or some other network connections.
If you're looking for the strongest protection, you may want to combine EE's parental controls with a gambling self-exclusion service such as GAMSTOP, plus any gambling blocks offered by your bank. That gives you protection across mobile data, WiFi and apps.
You can find EE's guide to managing parental controls here:
How do I turn on/off parental controls on mobiles
You can find tools and support here Control your gambling | Gamstop Online
Wishing you all the best, and shout if you need anything further.
Lesley
16-09-2026 06:38 PM
Gambling implies Adult! EE's Content Lock is being applied to adult sites. Are you on contract or PAYG?
Hi @Furrysides
Lesley
