11-07-2025 06:31 AM
Have been trying to get EE to merge my mobile and broadband accounts which are on separate email IDs to the same ID so I can access them both easily on the app. Every time I try to do this on the app I am told the accounts are already linked but my broadband info won't show.
When I contacted EE and told them about the issue they keep saying they will make a request to merge the accounts and it will take 3 to 5 days, then nothing happens. I have tried calling over 10 times going though this process and still no resolution.
11-07-2025 08:24 AM
Hi @Ma133a
You'll need to ask EE to delete one of those online accounts, then you can add another product on the app.
11-07-2025 08:52 AM
Hi @Ma133a
I'm disappointed to hear that the merge request still hasn't been completed for you yet, and I can imagine you're feeling a bit frustrated with having to call the team so often.
I would suggest calling back if you have the time to do so, opening a complaint, and then escalating this to a team leader for resolution.
You're also welcome to use the complaints webform, and a dedicated member of the team will respond to you within 7 days. Calling will be the quicker option, but I appreciate that you may rather do this online.
Linzi
