21-07-2026 10:12 PM
22-07-2026 08:44 AM
Hi @MoniaT.
Welcome to the community.
If your EE Hub supports Guest WiFi, you can create a separate network for visitors using the EE app.
Sign in to the EE app, head to Manage > Broadband, then scroll down to Guest WiFi and switch it on. You'll be asked to choose a network name and password before confirming the changes.
Your WiFi may disconnect while the settings are applied, but it should reconnect automatically afterwards.
Once set up, your guests can connect using the Guest WiFi name and password you've created, helping keep their devices separate from your main home network.
You can find more information on our Guest WiFi Help page.
Debbie
