Second corded phone
TimStevens
I want a second phone in another room in the house, but don't want wireless. So, can I plug a second corded phone into the Hub by using a "splitter", and then a cable to the other room? Will that work?
Maestro
Maestro
@TimStevens Yes, should be fine doing it that way.
That's great - many thanks.
What type of splitter and extension cable do I need?
@TimStevens   no offence meant, but if you have to ask is this project for you?
That said, if you get the right kit for the distance, something like this may be a simpler solution for you.
https://www.diy.com/departments/slx-white-telephone-extension-kit-20m/5028422001509_BQ.prd
HTH
