08-04-2026 02:49 AM
My mother has a old BT style Decor 110 phone plugged into an EE Digital Voice adapter. The phone sometimes loses a ring tone and is unable to make calls needing the EE DVA or EE router to be power cycled to get it working again.
Would buying a new phone like the BT Big Button 200 solve the reliability problem ?
08-04-2026 03:01 AM
@mark3099 : I should think unlikely; probably an ATA (what you're calling a DVA) issue.
Try the Decor 110 plugged into back of router. Is it still unreliable?
08-04-2026 03:12 AM
We have BT Duet 210 corded phone plugged into the EE router upstairs. It hasn't had any real issues unlike the Decor 110 plugged into an EE Home phone adapter (not sure exactly what the technically correct name is) downstairs.
08-04-2026 03:24 AM
The Decor 110 phone downstairs is connected to the EE adapter with a phone cable extension cord, could this be causing the problem?
08-04-2026 04:04 AM
There are quite a few reports that the ATA adapters are not as reliable as the Green Phone socket on the back of the router. I think that is what you are experiencing. The phone extension cable should not be an issue. Modern phones have almost 0 REN power consumption.
08-04-2026 04:35 PM
@mark3099 See if you can work out with the DVA on the light if anything specific is going on when the connection to it is lost or not working correctly.
What your Digital Voice
Adapter light means
1 On initial plug in – flashes 0.5 seconds on,
2 seconds off
2 During registration – flashes quickly
0.5 seconds on, 0.5 seconds off
3 Once registered – stays solid green
4 During a call – flashes slowly 1 second on,
1 second off
5 Once registered, if there’s a connection
problem with your broadband – flashes
0.5 seconds on and 2 seconds off.
09-04-2026 08:28 AM
@mark3099 The EE link if you happen to have the newer one.
