on 23-04-2026 08:26 PM
My landline is not working properly since I changed over from Plusnet. There are folk who cannot get through when they phone from their landline and others from there mobile.,
on 23-04-2026 08:31 PM
Hello @elainecarter762 ,
Welcome to the community,
Where have you plugged your landline? Have you plugged it in the router? Which is where you would have to plug it in with the new system.
on 23-04-2026 08:58 PM
But you may have plugged it into an ATA adapter remote from the router. That is also a valid place to plug it but may be less reliable than the back of the router. In which case try plugging it into the back of the router.
on 26-04-2026 09:37 PM
same, there is a dialtone, I can dial out, but when calling the landline, I get the number is not recognised
doesn't matter whether it is another landline or mobile
