Home phone handset ring tone won’t save
ShorehamNICK
Since changing my BT router to an EE one, I can no longer save the ring tone on my handset, I enjoyed a nice classical music clip which I can still select however it does not keep this when I use it
very frustrating
11 REPLIES 11
Mustrum
@ShorehamNICK   what model handset do you have?
It’s listed as the essential digital phone
Were you able to register it to the new router and are the other functions working OK?
Been looking at the manual, but can;t see any info re not saving ring tomes.
https://www.bt.com/content/dam/bt/help/digital-voice/essential-phone/BT-Essential-Digital-Home-Phone...
ShorehamNICK
Yes I retested both of the phones again when I switched over the router
, I was previously able to change the ring tone and save it,
the only thing that has changed is the router
Do you still have the BT router?
If so you could use that and let EE know that you need to use it to get the phones working and ask them to stop the return reminders.
Brilliant Contributor
@ShorehamNICK You can no longer use or select ringtones feature with the EE DV Service.
ShorehamNICK
Since being forced to move from BT to EE I have lost the ability to connect storage to my router and now I have to put up with a harsh ring tone on my phone ! I thought the switch would be an upgrade
anyone know if I can keep using by bt router ?
@ShorehamNICK   yes, see my earlier reply..
However without your MyBT your control options may be limited.
@ShorehamNICK As @Mustrum suggests if you still have the BT Smarthub2 put it back on, see how it goes and works before the switch over all get's confused. See what works, what does not, and what you need to do, your ringtone feature i do not think that you will get that back though, do let us know how it goes.
