DV Phones Not Displaying Time
drlabman
I've not seen this problem before, not with my current EE Smart Hub 7 Plus nor with my previous BT SH2.
Today I noticed that my upstairs DV phone was not displaying the wrong time - it was one hour ahead, as if it had missed the DST change a couple of weeks ago.  I tried a number of things to fix it - finally a hard reset (red button) and batteries out followed by restart ended up with no time being displayed at all, just dashes.  At least it wasn't wrong.  The only thing that corrected the display was a restart of the hub.
Then, I needed to change the batteries in the downstairs phone - following a couple of disconnected calls recently.  So, batteries out, new batteries in.  Restart phone ... no time displayed.  AI suggested that a deregister/reregister would correct it but it didn't.  A restart of the hub probably would, but I have "users" that don't like. the hub going offline for a couple of minutes.
The other thing I noticed is that there's no VOIP/SIP entries in the hub's log anymore, so debugging is impossible that way.
Anyone know of a better fix for the time display than restarting the hub?
34 REPLIES 34
These phones haven't had their firmware updated for ages AFAIK.
I've had a quick look at alternative phones.  Even thought about a Gigaset Box 100 to locate near the hub and then have a couple of their phones upstairs and downstairs - trouble is they come with German plug and I don't really want to use an adaptor is the place I want to locate it, and there was something about the phone cable (RJ11?) being a different form factor.
My old Panasonic phones were great - batteries seemed to last forever.
@drlabman Then think EE FW push to the DV phones, or doing a reset from the option that is on page 24, but would deregister it first and be careful not to select the base as that will be the EE Hub dect.
@drlabman Yes phone cord, i use the RJ11 connection directly plugged into my Grandstream ATA, as that is the connection type, phones are only two wire anyway pins 3&4 in use, as for the power most now come with PSU slider adapter's for the UK 3 pin socket's. Get all mine from this company never had any issues and they have good range off options as well.
Landline Telephones | Shop Latest Telephones – liGo.co.uk
Am I correct in thinking that third party phones, like the Gigaset, although they say "digital landline" would need to be plugged into the green socket on the back of the hub?  I ask because I don't want the downstairs phone close to the hub - not for electrical reasons, it's just not a convenient place.  That's why I was looking at the Gigaset Box 100, since that can be connected to the hub's green socket, tucked away behind a sofa or something, and the phone(s) can be elsewhere.
I suppose what I'm really asking is whether the DECT in the hub will talk to third party phones?
@drlabman Yes you can register a dect phone direct to the EE Hub, as to wither all the features would work as for a dedicated base station from the Gigaset manufacturer that is the question, although there is a basic GAP standard over and above the maker tweaks to sell extra features. look at the ligo link and long range phones, there is more than just the one type.
You will find i think on this part off the Forum that others have registered the phones direct to the EE Hub, not sure off the make/s etc but Panasonic does spring to mind. Will do a quick search. See this link and it was a BT version off a dect phone, Medallion Moose halve way down the post.
Solved: Additional DECT handsets issue - The EE Community
Not a good idea to block any transmitting device behind an object but you only can try, if the signal strength falls off you will need to have it in an open location.
