DV Phones Not Displaying Time
drlabman
I've not seen this problem before, not with my current EE Smart Hub 7 Plus nor with my previous BT SH2.
Today I noticed that my upstairs DV phone was not displaying the wrong time - it was one hour ahead, as if it had missed the DST change a couple of weeks ago.  I tried a number of things to fix it - finally a hard reset (red button) and batteries out followed by restart ended up with no time being displayed at all, just dashes.  At least it wasn't wrong.  The only thing that corrected the display was a restart of the hub.
Then, I needed to change the batteries in the downstairs phone - following a couple of disconnected calls recently.  So, batteries out, new batteries in.  Restart phone ... no time displayed.  AI suggested that a deregister/reregister would correct it but it didn't.  A restart of the hub probably would, but I have "users" that don't like. the hub going offline for a couple of minutes.
The other thing I noticed is that there's no VOIP/SIP entries in the hub's log anymore, so debugging is impossible that way.
Anyone know of a better fix for the time display than restarting the hub?
34 REPLIES 34
Yup, that's the one.  Threats of £65 if I didn't send it back - so I did.
Tomorrow.  We'll see
drlabman
Tried calling out and calling in.  No joy.  Phone still not displaying the time.
Other phone does display time.
@drlabman You may next try the hub reset if you can, if not working after that you could also try a text to EE CS it is PHONE to 66033. Also take a look at the call received to see if the CLI stamped the caller ID and the time stamp. Looks like it is on page 21 off the Essentials document calls list.
I'll have to wait for a suitable time to restart the hub.  It's annoying though, because now it seems every time I change the batteries in a phone I'll need to restart the hub.
Can you explain what texting PHONE to 66033 does?  I'd only be able to do that from my mobile, so how does it associate that number with my house number?
@drlabman From the registered mobile number on your EE account, then everything is known, the text initiates EE to go check and test the DV side landline phone operation, in theory once they have done it a call back and displayed on your mobile as EE / BT Guide calling to talk to you about what is going on. There are a few also HELP to get the BB checked, GUIDE to get a call back at EE/BT when someone picks it up to do so.
The restarting of the EE Hub is NOT A NEW issue, the batteries failing generally flags a fault and dropped connections, or when ringing on the phone the call get's dropped because the handset is just not up to the task. See the link below from the Help menu search. The rechargeable batteries will not last forever, if you get a good 2/3years out them might be worth planning the swap out, never used the DV models, got the trusty old Panasonic in play.
Fix common home phone faults | Home Phone Help | EE
You may have went from a Trusty old BT Smart Hub2 that just worked as expected to a piece of Junk.
Also take the phone down next to the working one incase it's struggling with the dect frequency connection on the EE Hub.
Thing is, I don't see how there can be anything wrong with the line - two phones show the correct time, one doesn't.  Did I mention I actually have 3 phones?  And an EE adaptor into which I plug a bog standard old school phone?
And the phone that's not displaying time is about 3 meters from the hub, with no interference between.
You're absolutely correct that the batteries don't last forever.  I've already changed them many times since I've had DV.  I could only dream of having two years out of them.  And I don't buy cheap ones - I buy Eneloop 800mAh.  The batteries have been such an issue (dropping of important calls, unable to handle speakerphone, etc) that I've just set up a charging schedule using smart TAPO plugs so that they only charge for a few hours a day.  Here's an example of how bad they are: I was making a call from one handset the other day, and another handset, which was still on its cradle and being charged, rebooted itself.  These phones, their cheap components and poor battery management deserve to be thrown in the bin.
@drlabman Are you sure the phone was not being FW updated as it's reboot process? We now are aware you have the three instead off the two. Plenty decent phones out there in the cordless market, pretty sure my batteries were the originals and phones in use for a good six years bought Jan 2021.
@drlabman wrote:
I don't see how there can be anything wrong with the line - two phones show the correct time, one doesn't.  .
Then consider the Essential DV phone is faulty.
Except yesterday it was a different phone that didn't display the time.
