What’s the difference between cooling off period from instore & online
Bionic69
Can someone tell me what’s the difference buying online than buying instore & cooling off period could someone please tell me .. thankyou 😃
@Bionic69 : 14 days!
If you ordered by phone or online you always have a statutory cooling-off period up to 14 days after delivery to cancel your order FoC. If you ordered in-store you have no such "change-of-mind" right of return.
Bionic69
does that include if  you can’t use the internet properly ? For example say You  have trouble using the internet & have to use Wi-Fi  to use the internet does that still constitute the same rights ? You don’t get a cooling off period because EE  can’t give a good signal  ?????
Bionic69
But that’s all wrong though as you still purchaseing from EE and the item is NOT fit for purpose as you can’t use the internet properly so that means if you had 5 gb to use ok & can’t use the 5gb then your not getting what you pay for !!!!
@Bionic69   That’s totally different.  A cooling of period is because the device is not in front of you and by law because as it’s not in front of you when you purchase online or over the phone you’re entitled to a cooling off period where you can then return the device.  A store  purchase the device in front of you so you don’t get that entitlement.  But If you don’t receive the quality of signal that you expect to receive at your home you can then return the device because of lack of signal.   Providing that lack of signal is outdoors as no network will guarantee signal indoors.  ( use Wi-Fi calling as that’s what it’s for )
The purchasing of data is not applicable to this this though.  Data purchases are add ons because you require data.  You already have an account/device and the ability to use data will depend on your location for that usage.
That wouldn't be a cooling-off period for a "change-of-mind" but your legal consumer right for goods not being "fit for purpose".
