on 11-05-2023 06:25 PM
I’m told I can now upgrade but to be honest I really need to downgrade as I just cannot afford £194.00 every month!!!!
Solved! Go to Solution.
on 11-05-2023 06:34 PM
Hi @Brodie1690
You can downgrade if your contact minimal term has come to an end. I suggest you speak to EE CS on 150 about how to reduced your bill.
Hi @Brodie1690
