15-09-2022 04:39 PM
No Frills what does it means
15-09-2022 05:43 PM
@Kamoom , what are you looking at? Is it to do with a plan you are wanting? If that is the case, then it means just the essential or basic plan. Here is the definition of it:
https://en.wikipedia.org/wiki/No_frills
15-09-2022 07:26 PM
"No Frills" is not & is below an Essentials Plan. You can't gift data on it.
