Moved to Australia
Jessicamccrum
Hello,
I have recently moved to Australia and continue to utilise/pay my monthly contract with EE as I have the roam abroad add on. I am going to require an Australian sim/contact number with a provider over here due to employment purposes but I still have at least 12 months or more left of my current contract with EE. Is there anyway that I could do some form of dual sim set up with an Australian provider/Sim?
Thanks in advance,
Jessica
@Jessicamccrum   Roaming is for short stays abroad max 2 months after this time you could incur roaming charges.
If your device supports 2 sims you just need to get a AUS sim and put it in your device.   If your device supports an eSim you’ll have to use that AUS number with the eSim as you can not change the EE number to the eSim while outside the UK.
Jessicamccrum
Great, thanks 🙂
