Monthly billing over charge.
Toyboy36
Valued Contributor
Valued Contributor
Hey there, am sending this message because l have been overcharged for my monthly  payment for my unlimited. I  was charged on 10th Sep 2024 for my monthly billing and on 18th Sep 2024 l was  charged again. I need to know if there were mistake or why was l charged twice.
9 REPLIES 9
Toyboy36
Valued Contributor
Valued Contributor
This month l have been over charged for my monthly bill.
@Toyboy36  Do you have any out of allowance charges?  This will show on bill.
Toyboy36
Valued Contributor
Valued Contributor
No I do not have any.
Lesley_W
Hi @Toyboy36
Thanks for coming to our community.
If you have been charged twice within the month, this is usually after a bill date change. Have you asked to change the date you pay your bill?
Lesley
Toyboy36
Valued Contributor
Valued Contributor
No I haven't ask to change. I usually pay on 10th of each an every month.
Lesley_W
Thanks for your reply @Toyboy36
Did the direct debit definitely go out on the 10th? Sometimes if a direct debit is unsuccessful, it will be taken again. If it was unsuccessful, your bank may display this as money going out and then back in after on the same day.
It's worth checking this isn't the case and them contacting our billing team who can check this for you.
Lesley
Toyboy36
Valued Contributor
Valued Contributor
Thank you so much. I would also want to change my address
Toyboy36
Valued Contributor
Valued Contributor
On 10th its shows the billing went through, then 18th l receive another billing from my bank notification  showing bill taken on that same day
killyouridols08
Prodigious Contributor
Same amount or different? I have 2 payments, 1 for a Flex-Pay device (Upgrade) and another for my Tariff.
