Mobile data
Misha09
I’m new to the EE network & I recently bought a £15 subscription pack but it only gave me 25gb of data when I thought it was supposed to be 50gb did that change I’m abit confused.
When did you buy this SIM? The current offer is 25GB.
Otherwise look in your online MyEE Add-ons for the other 25GB. Sometimes it doesn't kick in until have exhausted the normal ration.
I got the sim on 27th of jan and when I bought a £20 subscription pack it gave me 100gb and then I recently bought a £15 subscription pack and it gave me 25gb, so I thought that’s odd because I thought the packs were boosted with more data.
@Misha09 : You only get double data when you purchase a pack of equal or higher value than your original pack. You haven't!
Extra data promotion offer: Activate your SIM no later than 31.01.2024 to start receiving extra data. Join on the £10, £15 or £20 pack and receive extra data the first three times you purchase the same pack or pack of higher value. 12GB of extra data on a £10 pack, 25GB on a £15 pack and 50GB on a £20 pack. Maximum of three pack purchases then standard pack allowances apply: 8GB for £10, 25GB for £15 and 50GB for £20. Renew your pack within 30 days to keep extra data. Extra data will not roll over. You must purchase your 3rd pack before 20.05.2024 to receive extra data on all 3 packs.
