I want too reduce my payments
Smazzer119
I want too reduce my monthly payments
@Smazzer119  Are you due an upgrade?  Until you’re within your upgrade period you can’t lower the cost.   The contract cost is for the agreed term including yearly price increases
Ali_A
Hi @Smazzer119
Just to add to the the advice from @Chris_B, if you are past any minimum term you can save money by dropping down to SIM only. The best way to order your plan change is through the EE app or on our website at Upgrade | EE where you can look at the options available.
Alternatively, you can call the upgrade team directly Contact Us | Upgrade | EE where a guide will be able to sort out the right plan and costs that match your needs.
Ali
