Extortionate phone bill.
EnglishInOz
My phone bill is £1,300 higher than normal this month due to making 9 phone calls to Australia. I mistakenly thought I was on wifi using data as FaceTime calls have never incurred a charge. I received a text from ee to say “your phone useage is higher than usual”, which yes that was true. Then my phone wouldn’t work at all, I had been cut off. I am wondering why the maximum amount of spending reaches as high as it does before it gets stopped? That’s pretty high, my bill is normally £28 a month! I called 150, they were not able to help but said to call back in 3 weeks at the end of my next billing period. He asked why I hadn’t put a spend cap on - I said I tried to do that but it didn’t work! The app is awful, it crashes and comes up with errors, the website is hit and miss too. He tried and he couldn’t apply my spend cap either! I have since tried a few times and still getting the same errors. I am now in Australia (with a roam pass) and I am not able to call 150, 0800 9566000 or 07953 966150 - the voice message says to contact my mobile provider directly. Well aside from writing a letter which will get there in 2 weeks time, there doesn’t seem to be an email address for ee anywhere I can find? I would like to apply the spend cap to my account to stop this from happening in the future and I can’t afford to pay £1300 for this phone bill. I have paid my monthly subscription as normal, I assume I will get a phone call because my bill is unpaid - so perhaps that might be the only way to get to speaking to someone about this. I only hope it’s not in the middle of the night!!
10 REPLIES 10
"Calls" made using apps are handled by your phone and the mobile network differently, including the charging.
If calls have appeared on your bill, they will have been direct-dialled using your phone's normal dialler app.
@EnglishInOz  Did you enable roaming on your account this isn’t done via the purchase of a billing add on like the roam abroad pass.    But I can see from the image you have a signal on the device.
So have you tried restarting the device ?
was this image take before or after being cut off ?
Where was you when you got cut off ?    Australia or UK. ? And no you’ll not get a phone call because the bill is so high.  You have to call them about this.
chistery
I can't imagine it applies to many now, but if your contract started before Oct 2018 it would error like this and you couldn't set a spend cap.
Schockwave
@EnglishInOz , if you have something like Skype, you can ring customer service for free and speak to them to sort this out. Look at my signature, you will find the number there to ring them.
If you were using FaceTime, then you should not be charged for making calls, but if that was made using a normal call, then yes you will be charged if ringing Australia from the UK, but obviously not if using something like FaceTime.
I was in the UK when I got cut off.
Yes allow roaming is on in my phone settings.
I took several images of the spend cap error page, before and after being cut off.
I can’t call ee from my mobile, not on any of the numbers, the voice message says to contact my mobile provider directly.
Yes I have restarted the phone.
I’ve had my contract with ee since 2016.
Yes I could use FaceTime on wifi after I was cut off - which is why I assumed voice calls would be included whilst I stayed within wifi, but I know now that is not the case.
The spend cap is there to stop people getting a large bill, I (and ee) are unable to apply the spend cap. Why is the cut off based on such a high amount? Isn’t say £300 more reasonable? This is where they have set the limit over £1,000 +VAT. That is the cost of two of my first cars!!! I clocked this up in a matter of 7 days.
I will have to set up Skype then by the looks of it, thanks for letting me know.
Yes, I understand and I definitely made the calls.
I’m just wondering why the ceiling limit is so high at cut off point and the text alert came after spending over £1,000+VAT. It may have been nice to get a text alert to say I have spent £300  - now that is unusual. In the last 8 years with ee I have never spent more than £100 in any month and I was only 8 days into the new month 🤷🏻‍♀️
Christopher_G
Hi @EnglishInOz
Welcome to the community.
I definitely recommend getting in touch with our Mobile Care team, using a VoIP service, such as the one mentioned. They'll be able to look into why you were unable to add a spend cap and help you try and get connected until the bill is produced and they can discuss the balance with you.
