28-04-2026 11:24 AM
I am wanting to cancel my broadband, or at least discuss reducing my monthly payments. Is there a way of doing this online or does it need to be in store?
28-04-2026 12:01 PM
Good luck with this. It is almost impossible to speak to anyone at EE. I have tried on line and in store without success
28-04-2026 12:42 PM
Hello @trober89 ,
Welcome to the community,
If you speak to the billing team, by pressing option 1, I believe for broadband, they should be able to help, otherwise try option 2 and they should be able to put you through to the broadband team, but if you are still within the minimum term, not sure whether you can reduce your monthly payments, you would have to ring customer service or maybe go into a store with photo ID, as you will need proof.
