Community Activity
Urgent help for roaming abroad
I am in Vietnam and trying to get a roaming pass! all of the solutions I’ve read in other forum posts don’t work. phone rings dead via 150 , +44 800 9566000, +44 7953 966no response on the text 150 when I text ROAMINGDATA ZERO help on the app. this i...
Leely by Visitor
  • 1 Views
  • 0 replies
  • 0 Helpful
Will location of FF hub adversly affect TV?
I currently have my EE TV box connected by wire directly to the HUB which is conveniently located behind the TV.On Tuesday we are having Full Fibre installed (hurrah!)We want the hub to be re- located in the hall which Open Reach can do.BUT will the ...
Marg0105 by Contributor
  • 47 Views
  • 2 replies
  • 1 Helpful
Roam Inclusive Package
I have just received a message that my Roam Inclusive Extra package has been removed from my plan.    I am in contract until November 2025 and as a frequent traveller use this regularly.    No reduction in price but a large part of the reason I took ...
NicRog by Visitor
  • 261 Views
  • 10 replies
  • 4 Helpful
Resolved! View of Bills online - not the app
Hi there,I only use the website to access my account details, I don't want to use the app.I am only able to see the current month and previous 2 months online where payments have been made to EE.Why is there no drop down option to see older payments ...
CTeam_22 by Visitor
  • 270 Views
  • 7 replies
  • 5 Helpful
Smart Hub Plus Router - replacement still not sent
I’ve got All Rounder Fibre broadband. On Friday morning, router started going through the rainbow of lights including white which according to the EE engineer when I phoned was ‘not good’. They said they would send new router and it should arrive nex...
Smart WiFi Pro connection
I recently moved over to EE from BT and have full fibre 900. I opted to pay the extra £7 for a Smart Hub Pro and Smart WiFi Pro, to replace my old BT Smart Hub 2 and WiFi Disc, which arrived promptly. The Smart Hub Pro was a breeze to set up, but the...
Loud buzz from EETV Pro box
I’ve only had my EETV box for a few days but the constant loud buzzing sound is driving me mad.  Is this normal for the EVTV Pro box?it doesn’t sound like a hard drive spinning, more like the buzzing you sometimes get when you put a really high power...
Davria by Investigator
  • 62 Views
  • 2 replies
  • 0 Helpful
EE app help page not loading.
Just recently updated my EE app and now the help tab won’t load on the iPhone app. I’ve reinstalled and also reset my phone with no success. Anyone else facing the same issue?
