18-04-2025 05:40 PM
I have recently paid for an early upgrade on my iPad but realised that I should have gone for a higher spec device. Would I be able to change this under the cooling off period rules?
Is it a PITA?
18-04-2025 05:46 PM
If you purchased the tablet via online or telesales, you have a statutory 14days "change of mind" right of return for whatever reason. This does not apply to in-store face-to-face purchases.
https://ee.co.uk/help/orders/how-to-return-a-product-bought-within-the-last-14-days
18-04-2025 05:46 PM
18-04-2025 05:47 PM
Not directly. If you ordered online or by phone you may cancel the order FoC before or during the statutory 14-day cooling-off period from delivery & then reorder what you really want.
18-04-2025 06:48 PM
Hi @Gump1976
Depends on how EE want to deal with the question as both @XRaySpeX and @bristolian are correct. If you have ordered before despatch then you might be able to amend, if not you're need to return and reorder.
