16-07-2022 03:40 PM
Hello. My landlord bought a new router which includes an EE Smart WiFi Disc. Router works fine and I have internet access throughout the house. However the Disk doesn't seem to work. I plugged it in and connect it to the router but the light is off. Is there a case that is still working with the light off? If not what's the process of returning the disk and receiving and replacement?
17-07-2022 08:59 AM
OK, thanks, @labrosvel.
I would suggest that the account holder speaks with our Technical Support team. They'll be able to run through some more diagnostics and run through options.
16-07-2022 08:05 PM
@labrosvel Have you switched the disk on ? The button is on the back.
16-07-2022 08:26 PM
Yes @Chris_B I have.
16-07-2022 09:29 PM
@labrosvel Are you using the EE home app at all ?
There is a small hole of the disk ( back of it ) push a pin in to it and hold it there to reset the disk. The disk has to have the power lead connected when you do this. Hold it there for 30+ seconds it should have the word RESET next to it.
do you get any lights on the disk even when you switch it on ?
16-07-2022 10:33 PM
@Chris_B No response whatsoever. No light at all. It is as if is not plugged in or the light doesn't work at all.
17-07-2022 08:36 AM
Hi @labrosvel
Could you try the plug in a different socket, just to see if it gets some power to the unit.
17-07-2022 08:56 AM
Hi @Christopher_G. Already tried different sockets and I tried them with other electrical devices to see if they work. Same result. I changed the socket now but still nothing.
17-07-2022 08:59 AM
