why is my Smart Wifi Pro extender often orange?
StuartTT
The light on my extender is orange for long periods then aqua. I'd say about half the time it's orange. Why is this? It's only two rooms away from the main router.
21 REPLIES 21
@StuartTT on the picture there will be XX:XX:XX: etc, smart people can use those to get to you by hacking, so when not shown eliminates all the issues etc, same as personal details... As i posted earlier the WEB Software and the EE App are by far NOT the sharpest tools, if your mesh is working fine, and you look at those -db figures, keep them low, it is surprising that where you think is best is maybe not correct, mesh is a minefield and sometimes just moving the unit to the other side off the room has a dramatic effect in operation. DONT worry about the fact it say's network connected, i trust the info with two pinches of salt!!
ok, understood. Many thanks again!
