30-05-2021 09:41 AM
Hello I have a second EE smart hub ( the black model with the EE logo in middle and the light above and below the logo). Since the wifi signal in the front bedroom is really low, was wondering how to connect the second hub upstairs using an existing lan cable already connected to main hub and using the second hub as a wifi booster but also using the lan on the second hub to connect a pc ( that is non wifi ) and a console to.
I saw instructions are already up but on the config page on hub I cannot see the settings, 2. Set Broadband Type of Secondary BB = Ethernet, under Basic Settings. CLICK SAVE.
Any help please
30-05-2021 10:40 AM
You're reading instructions for a Brightbox router. The equivalent for the EE SH is:
30-05-2021 10:42 AM
I have it work except this part... on the main router
8 Reserve the Secondary BB's Gateway IP Addy in the DHCP of the Primary BB.
You should not need to make any other changes to the Primary BB.
How do i do this ( sorry I am not tech savvy) but I do thank you for your help
30-05-2021 11:04 AM
@deb52 : The equivalent of Reserving an IP on the BB is "Always use this IP" in the Advanced / Network section of the EE SH.
06-06-2023 09:24 AM
Very simple...I've just done it for my main Vodafone fibre broadband router to an EE smart hub.
I have my main VF router in the lounge. I get no signal in my office downstairs so I put and new 2022 EE smart hub in my office. (Given to me)
All I had to do was run a cat 6 cable from a LAN socket on my main router to my office.
I then plugged this into LAN 1 on my EE router.
Logged in to the EE router and went to MY NETWORK - change settings (type in the password)
Click on IPv4 Configuration.
Hub gateway IP address
IP address (I then entered) 192.168.1.198
Subnet left as was 255.255.255.0
Made sure DCHP server was off.
I then got a connection.
The hub gateway IP address has to be similar to your main routers address, so if your main router is 192.168.1.1 then Set your HUB gateway IP to 192.168.1.198 (198 isn't usually used)
