on 02-07-2022 05:57 AM
i am not very technical but i do know when i had another provider i never had the problem of signal strength,if i face time on my mobile and walk out of the living room where the hub is i lose the signal,i live in a tiny 2 bedroom bungalow i noticed in the bedroom i lose the signal for Netflix etc also.Any ideas welcome but please keep it basic as i don't understand all the jargon lol
Thankyou in advance
Susan
on 02-07-2022 07:55 AM
@susielooe I take the hub is your router ? Have you tried repositioning your router to a different location ? The drop out is being caused by your home blocking the Wi-Fi signal from the router to your device.
on 02-07-2022 08:13 AM
Hi lol yes router I'm terrible with the correct words for these now 😅
Worth a try thankyou
on 02-07-2022 10:52 AM
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
