on 08-04-2024 08:59 PM
I placed an order for a new EE back on 23rd Dec 2023 from BT, but we were having issues with the order, so they put us on a temporary Package for New EE, and it was the following,
UPNP issue
Xbox
on 28-03-2024 04:54 PM
08-04-2024 09:25 PM - edited 08-04-2024 10:02 PM
How come your previous post on your old deleted profile had much more information on it?
Have you tried doing what the Xbox support page says first?
https://support.xbox.com/en-US/help/hardware-network/connect-network/upnp-not-successful
You would be best suited talking directly to EE for help on this, as they will be able to help you further.
on 09-04-2024 07:47 PM
After two days of using the Wifi controls after waiting since 23rd Dec 2023, I am still on the wrong package and can't see the broadband plan on the website or app.
But going back to the app and Wifi controls I can say it must buggy and slows app I have use
on 10-04-2024 08:51 AM
But going back to the app and Wifi controls I can say it must be buggy and slows app I have used
on 22-04-2024 02:25 PM
I ordered New EE back on 23 Dec 2023 on a temp package new package was meant to go live last month but never happened, I have an issue with UPnP where Xbox can't find UPnP from smart Hub plus someone was meant to get back to me about that and no one as also they were meant to get back to me with the issue with IPV6 not working, then after have the wifi controls finely working in the app after 6 months backward and frontward try to get fix and work when I set Smart Wifi plus they will say there to close to the hub or too far from the hub when they're in the same place I hand BT disc. They work fine they all always showed up as good singles in the BT app and hub UI. The smart Hub Plus will say I have nothing running on 2.4gz wifi. I have to Try to call 150 speaking to the team at EE and they all point this at hardware when this is a software issue as don't have an issue with Netgear RAX80 or BT Smart Hub.
