can I control devices connections to broadband from a computer?
Naspignac
Maestro
Maestro
@Naspignac Yes, as long as you have the correct software that allows the control of the devices on the pc and connected to the Router you are talking about, then it is possible to do so!
In what way do you want to control them? You can use WiFi Controls & Parental Controls of the app to control them to some extent.
