Worst internet connection
Michellep66
When I moved from Talk talk I was told I would be getting full fibre. First misinformation!!! Then the speeds were rubbish and if we have a few things running it can’t handle it. Feels like going back to the dark ages. Worst decision I ever made!!! Always had a phone through EE so thought internet would be reliable but no. Also now working from home and having the worst time
@Michellep66 : Welcome to EE's Home Broadband Forum.
