Wireless Broadband
Daisytaylor
Our wireless broadband is only working intermittently. Is there an internal problem that we need to fix or is there a bigger problem with our local signal or similar?
Mustrum
@Daisytaylor   this is not customer services, so know ones will know what your service is doing, unless you can provide a bit more information.
Is your service delivered over your phone line, if so is it working ok, is there any noise on the line?
Which router do you have and what lights are on/off when you have issues?
Have you had a look at the help pages? https://ee.co.uk/contact-ee/technical-support/broadband-landline
HTH
