Wired connection slow to connect
Neil0
When I switch on a device with a wired connection to my router (desktop or TV) there is a delay of several seconds before a connection is established.  Reliability and speed are excellent when connected but I did not experience this lag when I was previously with BT.
Cana anyone shed any light on this?
87 REPLIES 87
Richardr66
Expert Contributor
Expert Contributor
I haven't noticed this the past few days, and I see that my Smarthub [SH31B] has updated to:
r3.8.17-R-1464067-PROD-83002
Hopefully it is now fixed.
imacken
I wish i could say the same about the Smart Hub Pro!
Still problematic.
yetihunter
I'm also using the SH31B
with the firmware r3.8.17-R-1464067-PROD-83002
and the problem still occurs.
I wonder if the fix isn't in this patch yet (as @Steve_BT said it was going live around Dec/Jan)
or it didn't work for the hub we're using.
Are you able to confirm @Steve_BT ?
Thanks!
Nothing is fixed related to Ethernet delayed connection.
@Joe77x Not anywhere near the version that the EE guide stated as having the fix applied and tested as working! So going to be later down the road for that one!
imacken
It beggars belief that after several years of this issue, and over a year since the 'fix' was made, that still, there is no sign of this being rolled out.
Very, very frustrating.
@imacken As a long time user, you know what EE are like, you surely cannot be surprised by it all!
imacken
@JimM11 This is shocking, even for EE!
