Wifi signal
Brianbuckham
Valued Contributor
Valued Contributor
Wifi was brilliant last month got a new router sent out and the upload speed is shockingly slow 0.6mgb clearly states on the website I’d receive a minimum speed of 16 download speed isn’t even close to that what exactly am I paying for other than a terrible signal I can’t even get on ee website unless I use my data on my phone
12 REPLIES 12
Which routers have you changed from/to? Was this cuz you changed BB package? If so, which BB package have you changed from/to?
EE cancelled my broadband without any warning said that another broadband
supplier owned the line that I have to my house it worked brilliant for a
month then stopped so got in touch and they explained that another company
had cancelled my broadband cause they had the rental rights to the line and
not ee so I paid for an engineer to come and put a line in for me he didn’t
do it he just plugged the new router thst had been sent out into my phone
line it’s the same router as I had a month ago and I’m getting half the
signal I was 4 weeks ago
So I still need to know which router is it?
To whom did you pay for an engineer? Was it EE?
You really need to sort out which provider owns your line.
Brianbuckham
Valued Contributor
Valued Contributor
Wifi signal is and has been rubbish since I got it connected was guaranteed 16 mb and I’m getting 5.8 mb
@Brianbuckham   And how fast is a wired connection with the router ?  guaranteed speed is not over Wi-Fi it’s a wired connection.   Your home will have an effect on the Wi-Fi signal.
That is the signal strength with the Ethernet cable plugged in
Christopher_G
When was your line connected, @Brianbuckham? It could still be settling.
@Brianbuckham : Welcome to EE's Home Broadband Forum.
@Brianbuckham   So your doing that speed test via a PC/laptop that is directly connected to the router via a Ethernet cable to the router ?  That’s not Wi-Fi as Wi-Fi is a wireless connection to the router.
