Wifi 7 Extender issues
j33tco
Hey all,
Having an issue with the wifi extender on 1.6 busy home bundle.
Sat here constantly getting disconnects on my laptop, im sat approx 2m away from the router, and over 10m away from the extender, watching the logs, my laptop is constantly being bounced between the two, when connected to the hub, over 1.3gb speeds and no mess, then it jumps to the extender, sub 100mb dl speeds and lag and disconnection issues.
Is it possible to completely block a device from connecting to the extender, before I unplug it all together lol
Maestro
Maestro
@j33tco No, you have no control over the mesh or where the devices are going to jump wireless wi-fi connection, if your device is windows based, the properties for the wireless nic, roaming aggressiveness changing the value will more than likely help stay connected and stop the wireless jumping about from unit to unit!
