22-10-2025 09:59 AM
I have a client who has asked me the below query about EE wifi and I do not know the answer and I am hoping you can help with that and what band its broadcasting live on.
From my client
"There is a wifi called EE Wifi that is being advertised but not on all of the antennas
Can u have a look please?"
Background
I have looked up the wifi hotspots system and I can see it's only live on some locations https://ee-wifi.ee.co.uk/public/ee/find/index.htm
The client and our booster system is in Wolverhampton WV10, Fallings park area.
The mobile booster company I work for installed a mobile signal booster 18 months ago, it's a Ofcom approved legal unit and simple re-broadcasts what's outside giving full indoor EE coverage, all antenna are sent the same signal from the amplifier, if it helps here is all the details about the actual multiboost signal booster and it is broadcast EE on 2 channels 2010MHz and 1800MHz, actual frequencies below
1831.7 - 1876.7
1736.7 - 1781.7
and
2149.7 - 2169.7
1959.7 - 1979.7
Does anyone know
It's possible the wifi showing up under some antenna is not related to the booster itself, but without the booster the building has no signal so I feel there has to be some connection. Signal outside is perfect and only reason there is an issue indoors is the building is metal cladding.
Anyone any ideas?
Tom
23-10-2025 10:10 PM - edited 23-10-2025 10:24 PM
I'm 100% sure. It's nowt to do with antennae other than those embedded inside EE & BT routers. You may see some routers with the antennae sticking out like the 1 in my avatar but EE/EE don't build them like that. It's certainly nowt to do with the mobile antennae & boosters you are familiar with & is your field.
You must be familiar with the mobile phones' ability to switch between mobile signals & WiFi. It's 1 or t'other at a time.
You have read the Wikipedia article?
