Why is my broadband so poor
K1966
Why is my broadband so poor when I'm paying through the roof for it
[Mod edit: Please do not post personal information on the public board. Thanks!]
@K1966  have you call customer services to report an issue?  the amount you pay has nothing to faults if there is one.
