Waking PS5 from rest mode, not staying connected to internet.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-03-2025 08:46 PM
Hello. Recently migrated over from BT when my contract was up. Now with EE and using their smart hub.
My PS5 has all the correct features enabled and this worked no problem with the BT hub. But now when I start up my PS5 from rest mode it’s not connected to the internet and takes a min or 2 to connect.
This means I can’t download anything when it’s off and there is no auto update as it’s not connected to the internet when put in rest mode.
I have checked and re checked everything on the PS5. Removed the connection and re enabled it. Power cycled it. Tried it via WiFi and Ethernet cable.
I have reset my router. Used different port. I have given the PS5 a static ip. Nothing works. When connected there is no issue with the speed, it just disconnects when put in rest mode when it should not.
The issue is only since I have changed over from BT equipment. I am certain the issue is not the PS5. Any advice?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-03-2025 10:00 PM
@Pepps A reported feature seems to be a delay when a device connects to the internet, the switch seems to provide a more stable connection, especially on older devices.
Worth a try for under £15 https://www.amazon.co.uk/Network-Hubs-Switches/b?ie=UTF8&node=430573031
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-03-2025 09:14 PM
@Pepps you don't say which model router you have, but the issue has been reported before.
You could go back and use the BT Router, or you could try an ethernet switch between the router and the PS5.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-03-2025 09:23 PM
Hello. I have the smart hub plus. And I had to sent back my BT router. Why would a switch help? Thanks for your reply.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-03-2025 10:00 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-03-2025 10:06 PM
I’ll give it a go. Thank you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-03-2025 09:08 AM
This worked. Thank you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-03-2025 09:13 AM
@Pepps No worries, glad it has and thanks for coming back and letting us know.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-03-2025 06:26 PM
Hi. My PS5 is doing the same,ever since I switched to EE. Did this really work? Is it straight forward to do? Is it a case of connecting the router to the switch and then the switch to the PS5 with ethernet cables?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-03-2025 06:56 PM
@APS_83 yes, it is that simple. Just make sure you use good quality cables.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-03-2025 09:54 PM
Yep. Look at the link above on Amazon. I bought one of them. Plugged the Ethernet cable from my ee router into the switch. Then a Ethernet cable from the switch to the ps5 (you have to plug the switch into a socket as well for power) and it’s worked flawlessly since.
- Xbox won’t connect to online services in Gaming
- No Internet Connection in Broadband & Landline
- Repeated packet loss, high latency, loss of Internet connectivity in Mobile Broadband
- Internet connection continuously dropping out! in Broadband & Landline
- Always connected what a joke in Broadband & Landline
