WIFI Signal Booster
mhollands96
Good afternoon,  i have just switched to EE broadband but my signal upstairs isn't the best. Could someone recommend where i can get an EE signal booster.
many thanks in advance.
Maestro
Maestro
@mhollands96 Depending on the package that you signed upto with EE you may be entitled to one, what is it that you got from EE, if not covered then take a look at EE for smart wireless addon and see if that fits with expectations. Another option is the Router in the best place to send your wireless signal every where that you need it.
Manage and Use Broadband | Broadband Help | EE
What Affects Your Home Broadband Speed and WiFi | Broadband Help | EE
