Using a network switch with Smart hub plus
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-08-2024 09:35 AM
I currently have a managed network switch that connects to one port on my Smart Hub Plus.
This switch has about 12 ports connected.
Does it make any difference to performance or connections if i spread those connections out to the other 3 ports on the hub?
i.e. if i have 3 or 4 switches connected to each port, each switch had multiple connections, but there was less connected to one, if that makes sense.
Just curious....
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-08-2024 10:44 AM
@Trick97 You need to consult your managed switch information, the hub has no lan management in any format that you can do or change.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-08-2024 10:54 AM
@Trick97 I doubt you would notice much difference, you might see a little if the traffic was staying local to your LAN, but typically it is the WAN port and firewall that limits traffic .
- No NOW TV HD channels after 'migration' from BT in TV
- Can I use TP Link Deco Mesh with Smart Hub Plus (SH30A) in Broadband & Landline
- EE 5G Smart Hub, insanely poor jitter and not fit for gaming in Gaming
- Recent upgrade to EE Wifi 7 - Smart Wifi PRO will not pair in Broadband & Landline
- Frustration with connection to Samsung TV using HDMI and soundbar in TV
