Upgraded to Full Fibre and my landline doesn't work at all
Mackay54
I can neither ring out or receive calls on my landline. Caller ID, which is part of my plan worked for about 2 days. Anyone else had the problem, and how was it solved?
An EE presentative promised me some sort of adaptor, which never came. Are thse like the older ADSL filters we used to put on our phone lines?
14 REPLIES 14
Mustrum
@Mackay54  did you get a new router with a phone socket, and have you plugged your phone into this socket?
If yes, and you have one of the old ADSL dangly filters, then do give that a go. There have been reports that this will help.
Let us know how you get on.
HTH
No, they are not like ADSL filters. They are just like the ordinary BT phone sockets you used to have on the wall & are just the same as the phone socket on the router. You ought to be able to plug in to either any cordless DECT base station or any corded phone.
Tried that and sadly no success. has been referred to BT Openreach as EE customer service unable to resolve. Not optimistic.
Mackay54
Since the issue was referred to Openreach I have heard nothing , so my complaint could be being worked on, or not. I have no way of knowing.
This is unacceptably opaque. Ringing 150 to EE doesn’t solve the issue at all.  What is needed is a direct Customer Service and Complaints straight to BT Openreach.
I need to know if anything is actually happening to resolve the problem, when it is likely to be fixed and also if Openreach need access to my property in order to  effect a solution. How do I make direct contact?
Mystiqueen
There are ways to contact them here:
https://www.openreach.com/help-and-support/when-to-get-in-touch-with-openreach
Let me know how you get on. Must be annoying not having your phone line working.
@Mystiqueen   that link is not to get updates on faults - as the link suggests, any updaes will come from the Service Provider.
@Mackay54   If you contact EE they should be able to let you know what is happening and expected timescales.
https://ee.co.uk/contact-ee/technical-support/broadband-landline
Neil-O
Former EE Employee
Hi, @Mackay54 I'm really sorry you're having problems with your landline. Openreach would not normally be involved with a digital home phone fault unless there has been a problem porting the number. Did you get an update from the tech support team on the link @Mustrum posted?
Neil
I got a call from an EE engineer this morning to say they had reconfigured my landline phone setup from scratch at their end. So far so good. Caller ID and voicemail are working again. The potential involvement of BT Openreach was because the previous EE customer service person could not find a solution to the problem.
Regards,
Charles
My problem is similar; the phone is plugged into the router phone socket; outgoing calls are fine but incoming calls appear to be blocked; either the call cuts out or callers get the engaged tone. I no longer have an ADSL filter to try! This is a problem as the number is used for our holiday stay emergency calls.
