Unplug router
Karenb1
I am having extensive work done on the flat next week and need to unplug the router for the electrical work to be carried out. It will take around 2 weeks will this be OK?
@Karenb1   Yes it’s ok to unplug it.      If you can plug in it elsewhere and still connect back up you can do that also.
