Unable to connect laptop
Neil_F
Valued Contributor
Valued Contributor
Forced to move from BT to EE and it's been very stressful.
This morning I try to connect my laptop wirelessly to the router but it doesn't show up in the list to connect to!
Searched online to no avail. Plugged old BT router in and all fine.
Laptop just won't connect as list not showing new EE router.
Any tips appreciated
Neil_F
Valued Contributor
Valued Contributor
Upgraded to the latest driver for the network card and all good now.
Thx for replies
Which router is it? Have you disabled WiFi on it?
Neil_F
Valued Contributor
Valued Contributor
It's an EE smarthub plus. All my other devices show the router name except my laptop. I've not turned wifi off. Laptop shows nearby routers just not my new EE one!
How old is your lappy? Does it support 5 GHz WiFi? If not, try temporarily disabling the 5 GHz band on the Advanced > Advanced WiFi page.
Neil_F
Valued Contributor
Valued Contributor
They've sent me two now! ? £85 if I don't return it! Never wanted a second one.
Neil_F
Valued Contributor
Valued Contributor
Thx for replies
