TV buffering … slow broadband
DandL1
Continued buffering on TV while watching via WiFi …. I have the full speed package … wondering if anyone else has this . I have repeatedly raised it with EE help , put in boosters etc , but still it struggles . Never had this either BT ever ?
10 REPLIES 10
is anyone still getting buffering with EE , particularly evenings ? Since I switched from BT the buffering has really increased and spoils TV etc … I’m on 18mb fibre package guarantee but buffering continues
Is the buffering over WiFi or Ethernet or both?
Maestro
Maestro
@DandL1 What else has happened, better to start at the beginning. What router do you halve, which package are you on and go from there.
Why are we continuing to get horrendous buffering ; I have a guaranteed 18mbps package and yet my tv buffers every evening when it gets busy ( ie . 8pm ish until 10pm ish ) …. Apparently watching BBC iplayer should only take 2/3 mbps so why is EE broadband not working .  I can’t tolerate this much more … soon time to go elsewhere
2. Try both a wired & wireless speedtest, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
DandL1
Continued slow buffering as of today 18/12/24 …. I have posted my line speeds above …. It’s really awful . Why has the switch from BT to EE gone so badly and slowed the internet down .
You don't have a full speed package by any means but at most 24 Meg FTTC.
G8C
Same problem here lates WiFi router and extenders Speedtest indicate 700 mbps but constant buffering on BBC iplayer
