26-05-2026 12:38 PM
My download speed is very low outside my main hub
26-05-2026 12:42 PM
Have you run the speed test in the EE app? That will not only measure the raw BB connection speeds you are getting at the router as well as speeds to the device from which you are testing.
What is the name of the EE BB plan you are on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
