16-11-2026 05:42 AM - edited 16-11-2026 05:44 AM
Recently signed up to the 1.6Gb speed package, got my Smart Hub 7 Pro, & the speeds show great... Until I try to load any webpages, both on my hardwired PC & over wireless on my Samsung Galaxy Tab 11 Ultra,
I have to wait up to 20 minutes for a page to load, Even a simple Google search takes forever and at times I have to refresh several times, wait 10-20 then try again. I've done all the stuff like flushing DNS, releasing IP's and all that, factory reset the hub, the open reach Modem, reset the firewall on my PC even. An engineer even came out and found nothing wrong.... I only have few days before I can cancel without being charged...
should I be looking for another ISP?
16-11-2026 09:00 AM - edited 16-11-2026 09:51 AM
@Drysyn Have you asked EE CS to take a look see what is going on with your EE Smart Hub 7 Pro, send a text to them it is HELP to 66033 and they will test and check. The Pro is in a round of FW updates again so see were yours is at below is the last two versions.
FW: r5.16.1-R-2011329-PROD-1 and the gui is at App Version 3.17.5 20/08/2026
FW: r5.16.3-R-2091196-PROD-1 and the gui is at App Version 3.17.5 12/11/2026
With only two devices appearing to have issues and you say the speeds are great, then switch the Pro off for at least an hour and see if it paths better when connected again.
16-11-2026 09:55 AM
Logged into the router, seems to have have the latest firmware, IPV6 Enabled, IPV6 Network Status Disabled, DNS IPV 4 only, as I said, already had an engineer out last week,he found nothing wrong, but had a bit to say about the smart hub 7 pro not fully supporting IPV6, which I find strange since that is where the speed is coming from, I will have to get onto them about it, not going to pay almost £50 a month to not be able to use web browsers lol.
16-11-2026 10:08 AM
Try switching the DNS in the router, under Advanced > My Network > IPv4 Config > DNS Servers, away from EE's Auto ones to Manual with 1 of these public DNS pairs:
OpenDNS : 208.67.222.222 & 208.67.220.220 Google DNS: 8.8.8.8 & 8.8.4.4
Cloudflare DNS 1.1.1.1 & 1.0.0.1
16-11-2026 10:13 AM - edited 16-11-2026 10:14 AM
Changing the DNS to Google's was the first thing I tried, even set it at my PC too, as well IPV6 DNS as well, I spent a few days googling before I called for an engineer, He told me I should ask for a SH31B Router, but also said it'd be a big downgrade, I'd rather not have to downgrade
16-11-2026 10:27 AM
Yes, you wouldn't get your full speed across the LAN as the LAN ports on the SH6+ (SH31B) are only 1 Gig.
16-11-2026 12:10 PM - edited 16-11-2026 12:15 PM
@Drysyn Looks like you are getting a iPv6 address but to be sure check with What Is My IP Address - See Your Public Address - IPv4 & IPv6 it will list both iPv4/6 if the dual stack is giving it out, you do not need to go back to a 6+ hub that's a bag off nails. IpV6 in general is fine bur EE may be having a few issues implementing what they are doing, so do try switching it OFF at the hub level to start with, AND you will need to restart ALL your devices to wipe the iPv6 addresses off those.
I have not seen any off the Advanced WiFi iPv6 screens on EE now for a while, but you are just looking to disable the iPv6 from operating to start with.
16-11-2026 12:16 PM - edited 16-11-2026 12:20 PM
I have switched IPV6 off before at the hub and at my pc, speed instantly dropped to 125Mb/s until I turned it on, I know I am getting IPV6, my guess is that something is getting screwed somewhere at the web browser level, because Gaming, and Voice comms work just fine, It web browsing that sucks, been trying to load up Asda.com to do my shopping, been waiting with a spinning Icon for over 10 minutes, on Saturday it took over 19 minutes to do 4 mouse clicks and what should've been a 20 second job... I can't do with it being like that...
16-11-2026 12:19 PM - edited 16-11-2026 12:34 PM
@Drysyn No problem will leave you with it then. Keep an eye, 14 day's after you were activated EE wise that is all the time you have. Ping will let you know what stack you are using.
Microsoft Windows [Version 10.0.26300.9974]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>ping google.com
Pinging google.com [2a00:1450:4009:c15::8b] with 32 bytes of data:
Reply from 2a00:1450:4009:c15::8b: time=20ms
Reply from 2a00:1450:4009:c15::8b: time=21ms
Ping statistics for 2a00:1450:4009:c15::8b:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 20ms, Maximum = 21ms, Average = 20ms
C:\Windows\System32>ping bbc.com
Pinging bbc.com [2a04:4e42:400::81] with 32 bytes of data:
Reply from 2a04:4e42:400::81: time=15ms
Reply from 2a04:4e42:400::81: time=25ms
Reply from 2a04:4e42:400::81: time=16ms
Ping statistics for 2a04:4e42:400::81:
Minimum = 15ms, Maximum = 25ms, Average = 18ms
16-11-2026 01:33 PM - edited 16-11-2026 01:34 PM
Pings came back normal, but it's behaving itself now, wasn't when I was ordering my shopping it's totally Random, and usually it doesn't stay Ok for long, Baffling to say the least, though it is more behaved on the latest Firmware than it was last week, Also been getting Chunk errors.
C:\Windows\system32>Ping Google.com
Pinging Google.com [2a00:1450:4009:c17::65] with 32 bytes of data:
Reply from 2a00:1450:4009:c17::65: time=9ms
Reply from 2a00:1450:4009:c17::65: time=7ms
Reply from 2a00:1450:4009:c17::65: time=8ms
Ping statistics for 2a00:1450:4009:c17::65:
Minimum = 7ms, Maximum = 9ms, Average = 7ms
C:\Windows\system32>Ping BBC.com
Pinging BBC.com [2a04:4e42:200::81] with 32 bytes of data:
Reply from 2a04:4e42:200::81: time=7ms
Reply from 2a04:4e42:200::81: time=8ms
Ping statistics for 2a04:4e42:200::81:
Minimum = 7ms, Maximum = 8ms, Average = 7ms
