Smart wifi
dwood2002
I got my EE broadband 10 days ago. Everyday I have tried to set up the smart wifi on the EE home app and each time it is saying that it can’t connect to the network. I have followed all of the instructions on the app and the suggestions on what to try and nothing is working. What am I doing wrong? What can I do?
thanks in advance
D
13 REPLIES 13
Hi, its not my boardband its the EE Home app thats the problem as on the orignal thread above. Every time I try to connect it comes up with an error saying its not possible to connect to the network despite the fact my network is working fine. It seems its at a conflict with the app.
SB08RDY
Hi @James_B
Its not my boardband its the EE Home app thats the problem as on the orignal thread above. Every time I try to connect it comes up with an error saying its not possible to connect to the network despite the fact my network is working fine. It seems its at a conflict with the app.
James_B
EE Community Manager
Hi @SB08RDY,
Please get in touch with Technical Support so a member of the team can look into this for you.
They'll be happy to help. 🙂
Then don't use the app. It's not essential. Do it manually. Have you followed Setting up Smart WiFi & failing that Fixing problems with Smart WiFi ?
What fixes listed on other threads for iPhone have you tried? Is that to do with the app?
