Smart hub 2 /bt hub / another option
Gonz2
Last December moved to ee from Bt and got the smart hub + and three boosters. It was junk, constant drop off zooms for me and wife and multiple devices dropping connection. Sent it back and reverted to BT and discs. Question is 9 months later is it any better?
I also trialled a TP link deco x55 and had similar issues so went back to bt again- it seems like I have to many devices. Anyone got a router they would recommend or should I try the smart hub + again? Thanks all!
Well, is it? Only you would know!
Maestro
Maestro
@Gonz2 If your BT Smarthub2 and extenders are all working fine, then stick with that!
@Gonz2  I’ve not had any issues with my Smart hub plus.  I’ve got no extenders and I’m even receiving Wi-Fi in my utility room that I always had issues with when I had the smart hub and I had an extender for that.
