Smart Wifi Plus Discs not connecting as extenders
pst99
Valued Contributor
Valued Contributor
Hi, I've recently migrated to EE from BT and got all new Kit...Smart Hub Plus, 3 Smart Wifi Plus discs and Hybrid Connect.
No matter which way I add the Smart Wifi Plus discs I cannot get them to show up as extenders which means I can't manage them (i.e. turn the lights off as they are too bright at night in my bedroom) and I can't see through any interface which devices are connecting through them...
I've tried adding using a Cat5 cable, using WPS button on hub and adding through EE app. I always end up with the solid aqua light and they do appear to be working (I see the additional BSSIDs being broadcast against my SSID) but they stubbornly refuse to show up as extenders in the router admin interface or in the EE app.
Has anyone else experienced this and found a solution...or are there EE bods here that can help?
22 REPLIES 22
bobpullen
Star Contributor
Star Contributor
@pst99 wrote:
@bobpullen Yes, I have DHCP turned off on the router as I use a Raspberry Pi for DHCP so I have control over DNS (again, just like I used to on my BT setup).
Aha! Wouldn't explain the observation when trying with DHCP enabled, but worth you having a read of this thread .
pst99
Valued Contributor
Valued Contributor
@bobpullen Thanks, that looks like a sensible thing for me to do anyway...so as the extenders are using EE default DNS rather than that provided by my Pi (I use Adguard Home rather than Pi Hole...but similar idea).
As I say, I did try the discs before changing the DHCP stuff...but no harm in making them use EE DNS as I expect by the way EE are removing functionality from the router interface they very rarely test anything against non-vanilla configs...so may help for future updates 😉
bobpullen
Star Contributor
Star Contributor
@pst99 - let us know how you get on.
pst99
Valued Contributor
Valued Contributor
@bobpullen So my plan is as follows...
I have 3 discs all exhibiting the same behaviour...i.e. they appear to work but don't show up as extenders.
1 I'll leave alone...so standard DHCP client going through my Pi & Adguard (Cloudflare DNS)
2 Pi DHCP pointing it to the router for DNS. reboot but leave as is - ie already joined to the router
3 Pi DHCP pointing it to the router for DNS. Reset the disc and rejoin to the router
I'll feed back if I see anything different to what I'm seeing now..
pst99
Valued Contributor
Valued Contributor
So...they all now show up as Wifi Extenders...although the router is misbehaving a bit at the moment (gui hanging etc) so have rebooted everything and waiting for things to settle down
Just marking the mac addresses of the 3 extenders as except from adguard and telling the pi dhcp to point them at the router for DNS rather than at cloudflare appears to have done the trick...although this does not explain why they were not connecting properly before I'd disabled the router dhcp and connected the Pi...
Equally, one of the discs I'd reset (after exempting from adguard etc) and was still playing up until I'd rebooted it after having rejoined it to the network...
So...a few things at play here I think...but I think it's fair to say...extenders will not work if you have custom DNS/ad blockers... So whatever you use for DNS must point any extenders back at the smart hub plus (Thanks @bobpullen ) even if pointing your other clients at different DNS servers
pst99
Valued Contributor
Valued Contributor
I have the same issue. I have 3 extenders (as I had three discs when I migrated from BT).
The Smart Hub Plus UI shows no devices connected on any of the extenders, the EE app (when it eventually shows the extenders) shows what looks accurate as far as I can check.
Additionally, the 'positioning/connection' info appears different between the SH+ UI and the EE app... i.e. The UI (Under Wireless | Wifi Extenders) shows them all as 'Good connection' where as the EE app show one as being 'Too Close'
I have to say, since moving from BT to EE I have lots of teething issues, and the 'management' of my (and I do consider everything connected inside my house as MY) network is hopeless. I get that as a supplier they might be trying to dumb things down so we can't break things...but make it work first (and ideally have an advanced mode for people that want it to use the full functionality of the routers).
Historically (before digital voice) I used my own routers where I had full control of everything, but that isn't an option now...I would have to at least have the EE router plugged in for the digital voice. I'm not going to invest in an up to date mesh setup  unless I could get rid of the EE equipment entirely...i.e. If we could use 3rd party routers (that have DECT and support VOIP) with the digital voice service.
  1. I have exactly the same problem with the WiFi Plus extenders, but with additional problems.
  2. When the extender is connected to the router by WiFi it shows up, but is greyed out. Devices connected through it show a low Link Speed.
  3. When connected back to the router by ethernet the extender is invisible, and devices connected through it are also invisible, BUT they do connect and have a gigabit Link Speed, as reported by the device.
  4. If I connect a second extender using ethernet the extender shows the blue connection light, but the router screws up, allocating invalid IP addresses, eg 2 devices with the same IP, or an address that is not in the subnet at all.
  5. I surmise that the router allocates an address of 192.168.168.100 to any extender connected by ethernet, hence the clash.
  6. It also allocates this out-of-range address to devices connected through it, Even if that extender is removed, DHCP treats the invalid IP as 'Static' so the only escape is to change the IP to genuinely Static at the device, and put in all the correct addresses.
  7. Final insult: The router is supposed to show down and upload volumes for each device. It does not.
Conclusion: A major software update is urgently needed. The current "Smart Plus" router is much worse than the BT one it replaces.
@j0hnhartley1 Just a user on EE like yourself, but thank you for the very concise update to what is going on with the mesh, not many look to give as much detail in the operation, and i do not use EE smart wireless, purely Asus AI mesh in operation, The app and the web interface for extenders do not appear to be making it easy in determining anything of relevance, just cannot think why the operation is so fruitless.
Is your EE kit all just new, or have you had it for a while now?
All new, EE Smarthub + 3 extenders . Have booked an engineer visit for 25th Nov,  so will update IDC.
John
pst99
Valued Contributor
Valued Contributor
So, it's been a while....but somewhere along the line, one of the recent EE firmwares appears to have messed up my extenders again...
I still have adguard with all rules excluded for the smart wifi discs and with the ee router configured as the upstream dns server for them, but they no longer show up in the router gui/ee app as extenders...
In fact they don't even show up as online even though they are and I can ping them and they still appear to work as extenders...I reset one and re-added it...and it still joins and works (but obviously I can't manage it and turn the light off etc)
As a random aside it seems in the recent ee firmware - the ability to configure a custom dns server on dhcp has appeared...so I tried going back to ee dhcp and specifying my adguard box as dns...but annoyingly the ee router sets the dns you specify AND the EE router, which rather defeats the object....so I've gone back to adguard DHCP...
Grr...EE why are you messing with this stuff...it was working...and now it's not....
(And you still haven't put export contacts into the UI for Digital Phone!!)
Phil
