Smart WiFi extender
Cusco
Just setting up wifi extender but light won’t turn aqua but stays solid blue Is extender faulty -have done factory reset
Thanks for responding In fact I was too impatient I guess ! The smart wifi extender finally turned aqua after 45 minutes and a couple of resets and seems to be working normally now.
Many thanks
C .
Sent from my iPhone
Maestro
Maestro
@Cusco Which model of EE router and Extender do you have, model number can be found on each device? Link to show the definition of light status regarding Extender, Solid Blue says that it is good.
Fix Problems with Smart WiFi | Help | EE
Many thanks
C .
Sent from my iPhone
