Smart Wi Fi Pro
Juniper23
The light on my Smart WiFi Pro keeps changing to orange and I lose some of my connections.  If I turn it off and on again it seems to pick up the signal.  Certainly not what I thought I was paying for?  Can anyone help please?
9 REPLIES 9
Maestro
Maestro
@Juniper23 About what the lights mean and what is going on with your EE Smarthub Pro.
EE Smart Hub Pro lights | Broadband Help
Thanks for this, it is helpful but doesn’t solve my issue. It does confirm that I’m regularly losing internet connection.
The orange light comes on several times a day so obviously not a good thing.  I need to know how to fix it.
@Juniper23 What is actually lost when you go to the steady orange light, how many devices do you think are connected to the extender, you might see that in the app but best to take a look through the web manager http://192.168.1.254 will get you there, are all connections to it wireless or is there anything on one or both off the Ethernet ports. If you take a look at it check that the Smart Hub Pro and the Smart Wireless Pro are both on the same FW.
Indication on the EE side is only to try moving the unit closer as it is struggle with distance connection to the Router.
Fix a Problem with Smart WiFi | Broadband Help | EE
Mustrum
@Juniper23   to get your line problem fixed you should follow the steps in the help pages:
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
Closed now
Our lines are currently closed.
Opening hours:
Support for Deaf and hard of hearing customers
Closed now
Opening hours:
tnj
Skilled Contributor
Skilled Contributor
If the Smart Hub Pro and the Smart Wireless Pro are not on the same FW, what do you do?
@tnj Nothing, EE will update it sometime when they get round to it!
thanks for your response.
the whole reason I was pursued by EE to purchase the Smart Wireless Pro is because router is in one room and tv/etc are in different areas and the connection was not good. It’s an old property with thick walls.
I’ve placed the Smart Wireless Pro near the tv etc to solve this problem but it’s  not really working.
not sure how to resolve this.
Leanne_T
Morning @Juniper23
If you get in touch with our broadband tech guides, they will run some tests and let you know what is needed to get this resolved 🙂
Let us know how you get on.
@Juniper23 You wrote "
Sorry but just do not see any logic in this and any advice you where given is completely wrong, Pro is not the way to go, you seriously need to cable between the Pro Router and the Smart Wireless extender for a wired backhaul.
