Smart Hub SH31B coil whine
Staticcat
Getting a lot of coil whine from my smart hub. Sounds like it's full of insects. Anyone else had this issue?
Maestro
Maestro
@Staticcat Has been reported on the Forum before but not too many times, no outcome to any resolution regarding what can be done, you could try EE CS and report, if they send a replacement all you could do is see if you get the same issue from it.
Mustrum
@Staticcat   it has been reported also on other forums, and seems to happen on some modern routers.
As suggested a call to CS and ask for a replacement if it is disturbing you.
Neilski
Just got one, having the same issue 😞
Did you get a replacement, and if so, did that have the same issue?
